Re: Solo/Cue follows monitor mixer output
Originally Posted by
Nicholas R
Hi everyone!
Does SAC allow for the MON solo/cue function to follow the selected "monitor mixer"?
Common example is using SAC as the monitor engineer and needing to quickly hear/cue a specific mix (once the specific mix has been chosen) without needing to hit the actual SOLO button on the output bus.
Yes the output to the solo bus follows the selected mix, so if you select a mix that is setup to be a monitor mix, that's what you'll be hearing.
The only little annoyance i find with the SAC solobus and listening to monitor mixes is when you pan the master fader hard left or right to send the mix to only one physical output. When you do that and have the tap point set to "after fader" the sound on the solobus is also panned! To get around that I do the panning with a plugin patched post fader. It's no big deal but it's something to be aware of if you're listening on a wedge and can only hear half of the monitor mixes :-)
Peter Olsen
Hardware: Asus Prime Z690-P D4, Intel Core i5-12600K, 8 GB ram, 500GB NVMe SSD, 2 RayDAT, 2 DSB2408 preamp/converters.
OS: Windows 10. Buffer: 1X32.
