It's been a while since I've been here. It's good to see a few familiar names!
I have a problem.
This is what I did:
I recorded into SS using my normal rig. RME converters and interfaces. The sample rate is 44.1
With another laptop, I recorded the output of a Behringer x32 via USB, also into SS, the sample rate is 48
I was in a huge hurry, or I would have matched the sample rates on both machine. But, I didn't.
When I import the 48k files into the 44.1 session, they are too short. They lose sync, almost immediately. They are off by exactly 8.125 %, the difference between 48k and 44.1k.
I have changed the sample rate of the 48k files to 44.1k using Izotope Rx7. No change. Same issue.
I have changed just the "change tag only" option in Rx7. No change. Same issue.
I know there is an easy fix for this. I just can't seem to remember what it is. I would rather not have to time stretch all of the files.
What am I missing?
Thank you!
Scott
