Re: MultiTrack Entry Display Issues
Originally Posted by
Dave,
You stated, "...quick regeneration of the WPD file for a given WAV file can be done in the SF View by hitting the R key...."
As I do not employ SoundFile View, I launched the wave file which launched SoundFile view, which in turn, then redrew the view.
So, Dave, regardless, thanks for the tip! Much appreciated!
Good point. Yes, if the WPD file does not exist, any time you try to open the WAV in the SF View, the WPD will auto-generate. If you have no waveform in the MT because a WPD doesn't exist, a double-click on the relevant region entry will open it in the SF View, spontaneously creating the WPD. (in either case, no R key needed)
FWIW, sometimes regenerating a waveform is helpful, like if there's been some kind of EDL pointer corruption or the WPD no longer accurately reflects the WAV file. That's when the R key comes in.
