I have an EDL that won't open due to some corrupt plugin setting. The "trouble loading plugin" box opens, and Studio crashes after hitting the OK button a few times. I've been able to blend the edl into a blank one, but of course none of the
plugin information comes with it. I used EDL Investigator's Session Mover (which doesn't yet display plugin information) to create a new EDL, but it crashed the same way. I'm at a loss to find out which plugin it might be. All other EDL's that
use my regular plugs likely to be in this EDL open fine, and I haven't recently updated any of them. And unfortunately I cleared the undo history at some point.
As suggested by Steve Berson, I'm going to remove all the VST DLL's and try opening it as I add them back in. Any other suggestions are welcome also.
