Hi everyone,
When editing sermons and longer recordings, I use vari-speed to listen back at a higher speed and make my edits as I go (hoping for an MT playback speed control soon :-)) and I have a question about how my automation is handled.
When I set automation while in "vari-speed mode" everything is cool. When I take everything back to 100% (from 175% or whatever), my automation does not adjust to where it should be.
Here are the general steps I take:
- Insert .wav files (several tracks) on MT
- Go to Select mode and Ctrl-A to select all regions
- Alt-Right click and set vari-speed to 175%
- Listen all the way through and make edits and add automation in spots
- When done, Select mode, Alt-Right click and set back to 100%
- My automation is still written, but not in the correct spots
Does anyone have any ideas about this? Admittedly, I have not tried a lot of different things. My workaround is to split the region where I want to automate, and then after everything is set back to 100%, I go back and add automation. This is "ok", but sometimes I have a couple hundred edits and it can be time consuming.
Thanks for any ideas or showing me the obvious answer I missed!
David
