SawStudio sounds better to me than any other DAW out there.
But ... I am officially obsessed with the why.
You know, I can't sleep well thinking about this.
I am serious.
I know, I know, this is the 1,000,000th post about the engine's sound quality.
You might think this is futile. There seems no logical explanation to the percieved great sound quality of SAW. Nulling tests have been done. SAW nulls -inf when compared to other DAWs. But I swear I can hear the difference. Crystal-clear highs and lows. Sure. Call it off as "expectation bias". Whatever. SAW sounds (to me) like a console that is flat up to 200kHz.
I've done the tests. I mean, I believe in the scientific method. I expect to hear no differences. Today I matched a small mix that I did in SAWStudio with only fader moves in REAPER. I tried another one with VST plugins and fader movements (no internal effects). ABXed them with Foobar2000. No contest. I could pick up the SAW mix consistently. .. What the hell is going on?
I am going MAD.
SawStudio sounds like heaven.
But this makes me uneasy. Afraid. I mean ... what if something happens to Bob? (God forbid). How can the audio community continue without this software?
You see, I have become dependent on the program to create a mix that satisfies me. I can try mixing in another DAW, sure ... but the results are always lacking 'something'. That's probably why so many people obsess with plugins and summing boxes. There's 'something' missing.
See ... I really wanted to cry when I heard the mixes that Bud Johnson posted two days ago. They were mixed bone-dry. There were some overlapping frequencies. But it sounded so organic. When I heard the mixes I said "yup, this is the sound of SAW". Listen to SAW radio ... "it" is there in every mix.
But then again ... I could be NUTS. But then why can't I create mixes in other DAWs that that rival the ones I have done in SAW? What? are you going to attribute this to "workflow"? really?
Ok ... what about this theory:
What it phase cancelation tests do not tell all of the story?. Why are we using nulling tests when we can use bit-level comparisons?
ARGHHHHHHHHHHHHH!!!!!
Yep. I am nuts.
Shoot me.
What do you think about this? (go ahead, answer the poll).
