How do you guys side chain to FX in SAW ?? , like a gate or compressor ETC.
NOT native plugs !!!!
LAter
Buzz
LAter
Buzz
You don't... unless the specific plugin allows it.
at least I've no clue how
Lovingly signed,
Robert Randolph
Mike -
Sorry - afaik but if you want to do side chaining of FX in SAW - you need to use native FX!
Right now the side chain capable plugins I am aware of in SAW are the Levelizer and the JMS Audioware Program Compressor - http://www.jms-audioware.com/progcomp.htm
Best regards,
Steve Berson
Don't forget all the channels comps and gates can key off of any other channel... before or after.
Is this theorethically possible?
Can one program a SAW plugin that hosts a sidechaining VST plugin (with multiple inputs), and from the SAW plugin Key the audio from another track and feed it to the sidechaining input of the hosted plugin? If so, probably I could program it.
It would seem ( of course this would be a Feature request !! ) that the wrapper that the FX are in there could be the ability to select the inputs on the upper area where the Triangle is ??
I have no idea what this would take programming wise but it would be a nice addition to SAW IMO !! just another improvement ?
Later
Buzz
