Bob,
What's your suggestion for handling common plug-ins for both SAW and SAC? In my case, I have plenty of plugs in SAW which I don't want to use in SAC, but I'd prefer not to re-install everything I want. Would it be a big deal to have a link between the two, either by ini file or a dialog box, allowing the user to see a list of SAW plugs and select which ones are needed in SAC - leaving them where they are? Is this even possible? Or am I being lazy - should I just make a list and install them a second time? I was propmted by the recent updates in the Levelizer and Freq Analyzer - having to do two installs of your plugs is nice and easy (as long as the user remembers) but less so for other things such as the Anwida plugs.
Thanks
Dominic
