In my previous post, I asked if it would be okay to ask a ***8220;Behringer Mixer Question***8221; as it relates to SAWPlus32 use. I was given a green light, so sorry if anyone is annoyed by this.
My image (below) is low-res, so here***8217;s a hi-res link to the Behringer 1204 mixer, which BobL kindly suggested as a way to create a useful headphone mix from SAWPlus32: http://www.behringer.com/EN/Products/1204FX.aspx (updated link to revised Behringer site)
I certainly don***8217;t expect anybody to research this for me, but there is a Manual link there and a schematic (which baffles me) under the Add***8217;l Info link.
- My Mics are old, unbalanced Nakamichi with 1/4" plugs.
- My current soundcard is just a stereo SoundBlaster with stereo mini plug I/O, that I adapt to RCA or 1/4***8221; as needed.
I want to record a mono track while listening to multiple pre-existing SAWPlus32 tracks - played back from the SoundBlaster card. My current decrepit mixer arrangement combines EVERYTHING entering its input channels (no submix capability) so the reference tracks material gets recorded onto the new/hot track (right along with the intended channel 1 microphone audio material).
Question 1: (see image) Is this how I would employ the Behringer 1204 to achieve a headphone mix that does not infect the mic***8217;d audio as it***8217;s being recorded?
Question 2: In the illustration, the reference tracks come in via channel 5/6, and that material is routed to ALT 3/4 as a submix. How would I route the 3/4 submix into my headphone mix, but not into the main output? (in this case, the main output exits the mixer via the CD/Tape Out RCA jacks, which mirror the balanced Main Outputs)
Question 3: Input channels 1-4 have balanced Mic inputs and ¼***8221; unbalanced Line inputs, each with a +10 / -40db attenuator pot. Can I connect my old unbalanced Nakamichi mikes to the ¼***8221; input and adjust gain for a quality signal?
Question 4: The ***8220;FX***8221; model of the Xenyx 1204 has internal effects costing just a few extra bucks. Are they any good?
Question 5: I read some pretty damning comments about the product quality and general reputation of Behringer. Do you guys think the 1204 is reliable, and will provide good audio quality? The price is RIGHT, but if it***8217;s just going to be trouble, I***8217;d rather ask you for additional mixer suggestions***8230;
Thanks
