Which display adapter would you suggest for a "remote controlled only" system?
I mean, which card do you believe would place the minimum load on the system?
(It would be used only for diagnostic purposes).
This is the MB I'd use:
http://www.asrock.com/mb/overview.asp?Model=P45XE
Thanks in advance.
