OK, not necessarily meant to be a specific accusation towards you, but I haven't talked to "other guys" that have used M7s because I've used them myself, and Midas Legends, and so forth. Some people think vinyl sounds better than CDs too...it's all subjective. My point is that what's considered "better" is just a load of junk for the most part, marketing people with too much time on their hands. The most important piece of equipment in any signal chain is the people being miced or amplified in some way and the guy controlling how that sound gets to the audience.
A good engineer can get the best out even marginal equipment the same way a great guitar player could probably use some cheap $100 guitar and sound way better than some average player on the most expensive guitar/amp/strings/etc... you could afford.
It's like the high end audio guys talking about $5000 interconnects. Seriously? Who cares. If the system sounds better and you can scientifically attribute it to the mic pres, that's awesome. The fact is that 99.9% of the people listening to your production or show won't have a clue if you are using a Telefunken U47 or a SM57 for a mic either.
I mean is it the mic pres or the way they are being used? I can certainly see in a recording environment using impedance matched inputs and Telefunkens, and Neve Mic pres, and so on...and you certainly may have a completely different use for your skills than I do. Me? I mix live bands in small to moderate sized venues and even at the smaller shows the audience just talking to each other is at 85+ dB, so that little extra clarity I could get out of a nice mic pre is just bouncing off the ceiling into someones head.
I've mixed with a Mackie 16 channel mixer with JBL TR125 tops and behringer amps and gotten compliments on how good it sounded. On the other hand I've been behind a Midas Legend and had problems. It is most certainly easier to work with good equipment, don't get me wrong. It's also just as easy to get someone behind that "good equipment" that isn't comfortable with it, and it'll sound bad no matter how expensive the Digico/D&B/Lab Gruppen/etc...system is.
